1 - 10 of 10 Posts
Hi Guys
Any free/cheap suggestions to improving my acceleration?
Close to 140 bhp now, but just want a pinch more.
Can i exchange my inlet for one from a 2.5 for example?
Any help with this would be sweet.
Thanks in advance.
Millions of them.
Chip is the only thing that is really worth it unless you plan on spending major money/time working on it to get power out of it.
m20 flywheel/clutch is a good upgrade if you have a dual mass flywheel; cams can be reground, but that's not cheap and it's a lot of work ...
Really, IMO, if you want more power than what you're gonna get with a good chip, you might as well look into swapping your engine for a m50/m52/s50.
edit: as for the intake ... nothing you do will get you power: the real bottleneck/restriction is the barn door air flow meter. That said, BMW got pretty much everything they could out of this motor within reason: it has dual butterfly throttle body, intake manifold with dual runners, factory headers ...
Discussion Starter · #5 · (Edited)
Thanks for your replys
M3 Would obviously be the choice, but not my wallets.
I was thinking more along the lines of superchip.
What if i take the MAF air flow sensor unit from a 2.5 and the inlet?
Any body know.
Injectors?
Or i am just lost in hope of some extra drifting power?
Millions of them.
Any body know.
Injectors?
You can't take a MAF from a m50. It is a hotwire maf and the m42 uses a vane AFM ... they work in completely different ways. There are conversions out there, but they are quite pricey. Look up splitsec.com ... I know they used to make a MAF conversion kit. If you meant a larger AFM from a m20 2.5, that wont work either ... the a/f ratio will be all out of whack.
Really though, if you can't afford a m50, start stripping the car out ... from what I've seen online, there is at least about 250-300 lbs that can be lost. If that's not an option either ... I don't know what to tell you, but it's gonna be pretty hard to drift.
Millions of them.
I don't know if they still do, but honestly, I don't think it's really very cost effective at all ... you spend 4 grand to basically get the same power as a stock M3 when a m50 swap with s50 cams, intake, chip and exhaust will only set you back half that and make the same power ... for the cost of a DA supercharger for a m42, you can probably have a aforementioned m50 swap with a low(ish) boost turbo setup.
1 - 10 of 10 Posts
