OK, so I got this set of CCFL Angel Eyes as a gift (4 rings + 4 clips + 2 inverters), but NO relay, NO fuse...
All the DIY threads on this topic that I've found thus far show how to connect the rings using a relay...but what about if you don't have a relay? On the inverter it says (-) to ground and (+) power from DRL, so how exactly do I do that...open the ECU box and tap the (+) into the red/white + yellow stripe wire?...if yes, would that also dim my Angel Eyes to 30% power, as per the DRL?
Any help with wiring these without a relay would be greatly appreciated.
Thx
Thx
