It's really not that complicated.
Step 1 open your hood
Step 2 in screw cap to the 20 pin connector.
Step 3 take piece of electrical wire and have one spliced end in pin #7 and another in pin #19
Step 4 get in the car and put key in and turn key to position 1 when the car electronics first receive power
Step 5 the bottom of the cluster will show the oil meter for a few brief moments and it will then disappear. When that meter disappears is when u immediately power down the car completely and take the key out of the ignition.
Step 6 get out of the car and take the wire out of the 20 pin connector and close up the screw cap again **NOTE** it only goes on one way. Now go back inside and put the key in and place back in position one. You should notice that this time the oil meter should be all the way to the left and green telling you you did this correctly.
Step 7 wrap everything up because you have successfully reset the oil service light single handedly.
Sent from my iPhone using AutoGuide.com Free App
