1 - 9 of 9 Posts
There is the plastic cover you take off by turniong the little handle deal and pulling. Then disconnect the plug carefully. Then take off the four nuts with a 8mm socket. Then just push from the inside and pop them out.
if they have never been taken out before than they might be very snug in there, so a decent push is needed, but make sure you have all the nuts and bolts out.
I just took mine out, they were very tight probably like yours. I gave the bolts a little tap being careful not to bend the bolts and then they will get loose.
What is film spraying?
i had a question about tail lights
i drive a convertible i want to get like the clear tail lights.
do i get the 4dr or the 2dr ?
2 door
1 - 9 of 9 Posts
