i have a 320td 03 and need help on how to reset the servie due in.. mileage on start up....... please reply !?!!
All you need to do is HOLD the left odometer reset button WHILE turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done. Here it is in video form: Blogworthy
BTW, a little effort using the search function or a search engine would have helped you find this answer sooner.
Good luck :)
thanks for the help DZ, have you read my post about help with performance, its half way down or so the first page on forum, do u have any help or advice on that post ??
