1 - 9 of 9 Posts
How do I fix the driver door creak/rattel, the driver door creaks going over bumps. Its a 1999 323i.
man~ i feel ya...
I got a 2003 325i with only 17k miles and it's doing the same shit...
rattles all the time especially when the window is up...
let me know if you find anything out.
JOhn
It's also happening on my 2002 325i. To me, it sounded like a low pitched "squeak" that goes away when I lower the windows. I let a friend drive it while I sat in the passenger seat (where the problem is worse) and I could make the sound stop if I put a LOT of pressure against the top of the window.
I'm going to try and lube the top of the window, but I'm not sure what to use. Please let me know if you guys figure out something that works. It really is annoying.
-Dean
Im about to call the dealer and try to get if fixed under warranty. Paid almost 40k for this ~ so I expect a little more quality
I am in the process of purchasing a 2001 325i that has precisely the same problem. There is a squeak/crackling noise coming from the top of all four windows when accelerating, braking, and going over bumps. Rolling down the windows very slightly to relieve the pressure seems to eliminate most of the squeaking.
I had the dealer service dept. lube the window seals, and the problem is still there. The mechanic said it may have something to do with the window guides, and not just the seals, but he wasn't quite sure. He said that they may need to tear the doors apart to figure it out. Sounds VERY expensive!
Someone (not the dealer mechanic) suggested that reducing the travel/force on the power window motors (if possible) might eliminate the noise. Does anyone know if this type of adjustment is possible?
I would be very interested in knowing if there is a solution. It seems from the posts here that this is a fairly common problem.
ya i had the some thing on my drivers door, what happens is, there are bolts inside the door that will back out, you just have to get in their and tighten them, then put on some locktite to prevent it from happening again. :thumbs
[snapback]197345[/snapback]​
Thanks for the quick response!
Could you please provide more detail on the location of these bolts, and how to obtain access to them? I imagine that these bolts are probably located on the narrow part of the door, above the window somewhere, and they they hold the window guides in place? Is this a simple fix, or does it require removing trim, door panels, etc? :confused
they are behind the door panel, you have to take it off, i think it is held on by screws, the bently manual has the locations, for your car.
if you just get the door panel off, you should be able to see what bolts they are, or just look for the loose ones. :wink
[snapback]197610[/snapback]​
Thanks for the extra info. Instead of taking the door apart, I tried the suggestion (linked below) about lubing the door/A-pillar seal (not the window seal), and it fixed the problem completely!
http://www.bmw-forums.com/forum/index.php?...topic=15678&hl=
1 - 9 of 9 Posts
