This is long and may be slightly complicated, please bear with me!
I am looking for advice into any and all of the points that follow.
I just bought a 2001 325i on 22-3-2010, before i bought it was just an i , but after i started signing the papers he started saying it may be an Xi, because it has something in the front aswell as the rear indicating it is AWD
So far i have driven it home(~150miles),driven to two inspection stations, Failed both times,
First place(Ayers), did a post purchase inspection and also state inspection for a sticker(living in maine, usa)
Post purchase inspection lists the following:
RED asterisked things indicated state inspection items
----TIRES:
- 3 different brands of tyres on vehicle. should be all same brand for all-wheel drive vehicle
- RR TYRE IS AT WEAR BARS*
- SPARE TYRE IS FLAT
---- SUSPENSION & STEERING:
- RIGHT REAR TIRE AT WEAR BARS*
- LT & RT FRONT INNER BALL JOINTS*
- LT FRONT OUTER BALL JOINT*
- BOTH REAR COIL SPRINGS BROKEN *
- FRONT CONTROL ARM BUSHINGS WORN*
- LT & RT FRONT AXLES
- POWER STEERING HOSES ARE LEAKING
----- DRIVE TRAIN & TRANS:
- LT FRONT AXLE BOOT TORN AND THERE IS SILICONE OVER THE TEAR*
- TRANSFER CASE MOUNT WORN
- SHIFTER STICKING
---- ENGINE:
- VEHICLE OVERDUE FOR INSPECTION II BY ~3500 MILES AS OF TIME OF POSTING
- WATER PUMP LOOKS ORIGINAL (NOT GOOD)
- AIR INTAKE BOOT IS TORN
- COOLANT EXPANSION TANK IS ORIGINAL
- MASSIVE OIL LEAK FRONT LT CORNER OF ENGINE*(MAYBE OIL FILTER STAND GASKET),
Because of this:
-Drive belts are saturated with oil*
-Both coolant expansion tank hoses are swollen with oil*
- CODE STORED FOR FAULTY THERMAL OIL LEVEL SENSOR
- NEEDS CRANKCASE VENT VALVE UPDATE
----BRAKES:
- FRONT BRAKES PADS ARE NEW, BUT BRAKE ROTORS ARE OLD AND SLIGHTLY RUSTY AND FRONT PAD SENSOR IS BAD ( CAUSING BRAKE WARNING LIGHT ON DASH)*
----BODY MECHANICAL & TRIM:
- WINDSHIELD WASHER NOZZLES AND HOSES ARE MISSING*
- WINDSHIELD WIPERS ARE UNUSABLE AND AFTERMARKET, SO INSERTS CANNOT BE REPLACED*
- HEADLIGHT LENSES ARE FROSTED (I bought 3M kit that is used with household drill 1200-1600 rpm, have not used it yet)*
- BATTERY NOT VENTED TO OUTSIDE
- CLIPS FOR WOOD TRIM ON LT REAR DOOR BROKEN
- RT FRONT WINDOW IS BINDING, NEEDS WINDOW REGULATOR ( I actually didn't realize they said the the FT RT window, because if any of them seem to be shaky or struggling, it would be the REAR RT window)
- LT REAR WINDOW SWITCH BROKEN
- ENGINE SPLASH SHIELD MISSING
- LT & RT FRONT JACK PADS MISSING
- LT REAR C-PILLAR TRIM MISSING
Listed for FAILED state inspection items on final quote:
- MASSIVE OIL LEAK FRONT LT CORNER OF ENGINE(MAYBE OIL FILTER STAND GASKET)
- DRIVE BELTS SATURATED WITH OIL
- BOTH COOLANT EXPANSION TANK HOSES SWOLLEN WITH OIL
The Second place (Kimballs)[VW dealer/service],
listed for FAILED state inspection items:
- LF LOWER BALLJOINT
- 2 REAR COIL SPRINGS
- 1 RR TYRE
- OIL LEAKING FROM UPPER ENGINE AREA
The second place seems much more lenient but is a trusted person with my girlfriends vehicle...
If you have made it down to here i THANK YOU VERY MUCH for reading and please get back to with answers/advice to my problems,
note that being under the 30 day warranty still, it will be getting serviced soon, the dealer (hughesmotors) [NEVER BUY FROM THEM, in methuen, massachusettes] refused the first bill of repair from ayers, then refused the second bill of repair from Kimballs, and said they would take care of the repairs.
Now i don't know what i should expect from this guy.
thank you and any information/links about any of my problems would be GREATLY appreciated.
Edit/Delete Message
----TIRES:
- SHIFTER STICKING
---- ENGINE:
Because of this:
----BRAKES:
- 1 RR TYRE
Edit/Delete Message
