1 - 11 of 11 Posts
i just bought an 87 325 two months ago. i bought it for $425 with 177,000. so i know it needed some work. i was able to do the brakes, change the oil, trans. kit, spark plugs and rotor cap. major things done for the front bushings, exhaust system, drive shaft, and i just had my timing chain all the belts and a new water pump put in. This car runs unbelievably well. Now i know why people love these cars so much.
I am just tying up some loose ends now. My rear defrost does not work, does anyone have any adice. thanks for help.
try the relay or the fuse for it. switch may also be bad. you can try and ohm out the switch
welcome
Hey adonis, coolesst sig I seen so far is yours!
1 - 11 of 11 Posts
