Hi guyz!
new here:)
I've got a 95 318 TI (compact) and i'm looking for 3 upgrades:
- a limited slip differential. what other bmw 3 series have LSD? will they fit here?
I was wondering if the E30 320is diff or 325i would fit. I searched Quaife Diffs but its a bit too expensive! any ideas?
- New camshaft for a bit more power but mostly more torque and power availability! where can i buy such thing?(UK) and how much would i be looking to spend?
- I will also change the spark plugs and cables. The cables will be Magnecor, what sparkplugs should i use?
thanks for ur help!:D
about £400. me and my mates will do all the fittings..
I'm looking for other 3 series with LSD cause it'll be easier and cheaper to get my hands on one
I know the e36 318 can only use other 318 diffs. Since the ti uses the e30 parts, i dont know if its the same for them aswell, but an e30 325 might not fit.
Fatty could point you in the right direction for cams in the UK
Bosch platinum plugs are supposed to be good for our cars.
