Status
Not open for further replies.
1 - 14 of 14 Posts
· 42, The meaning of life
Is there a pattern to when this happens, like if the car is really hot, or if you have been using the Air Con, or is it just the battery is connected the fan is on? Does it ever turn off, or will it run until your battery is flat?
Discussion Starter · #8 ·
No, I can just turn on the ignition {in the garage] and the heater on off, and the fans run,very odd, it has just started doing it???
Possibly one of the control modules is faulty if this is only happening with the ignition on. Try disconnecting the battery for 20 minutes and then reconnect. Make sure that you have any codes that might be asked for when the power is reconnected.
Discussion Starter · #10 ·
Thanks, I will try that.
I guess you need to find out what module controls the blower and look around the web for a changeover unit that might resolve this issue. I don't have much other advice to offer you.
1 - 14 of 14 Posts
Status
