yea i have read the online guides and manuals etc all looks pretty simple some say the e30 heater core is really easy but......... how the hek do you do it in a right hand drive when you have that massive brake assembly bracket jamed right up against where you need to tighten the screw to the valve? any help appreciated
If i cant work it out i am going to cut that little metal clamp bit of that holds the pipes in place
Discussion Starter · #2 ·
i figured it out remove the plug that is stuck to the underside of the dash above the heater valve
