Highly sought after 1997 BMW e36 M3/4/5 ‘slicktop’ sedan in Arctic Silver. This vehicle has been enthusiast owned through 4 owners, originally purchased as a track car and optioned with minimal accessories from the factory. I acquired the vehicle in 2016 after substantial overhauls to cooling and engine components by the previous owner. Maintenance and upgrades have been completed to maintain reliability and enhance track day performance. This is a very reliable e36 M3 track car and is driven to and from the track 3-5 events per year around the mid-atlantic (NJMP, Pocono, Summit, WGI) and the car has never left me stranded.
Clean PA title in hand.
Additional photos can be viewed here:
https://docs.google.com/document/d/1...it?usp=sharing
UPGRADES & MODIFICATIONS INCLUDE:
Engine/Cooling/Transmission:
  • VAC baffled oil pan
  • Upgraded oil pump shaft and bolt
  • Shark Injector software tune
  • Fan delete kit (electric aux fan installed)
  • Mishimoto radiator
  • Metal impeller water pump with ECS Water pump pulley
  • Lower temp coolant sensor
  • AKG Motorsport 75d poly Engine mounts
  • AKG Motorsport 75d poly Transmission mounts
  • Garagistic Chassis mount shifter - New 6/2021
  • UUC DSSR - New 6/2021
  • Stock exhaust
  • Stock S52 motor
Suspension:
  • H&R Sport Coil overs
  • SPC Camber plates
  • Racing Dynamics front strut brace
  • X-brace
  • Adjustable sway bars
  • Track alignment
Brakes:
  • Hawk DTC-70 pads - New 9/2021
  • OEM brake lines - New 6/2021
  • StopTech slotted rotors (front) - New 9/2021
  • Zimmerman blank rotors (rear) - New 9/2021
  • Remanufactured /M Calipers - 9/2021
  • Castrol SRF Flush - 9/2021
Wheels/Tires:
  • Original “M” DS2 Wheels; 17 x 8.5” square setup
  • Dunlop Direzza ZIII 245/40/17 - New 9/2021 (1.5 track days of use)
  • ECS Spacers
  • Wheel studs conversion
Safety/Interior:
This vehicle is prepped specifically for track days. There is no backseat, no interior door panels. The original carpet, headliner, dashboard and center console are all in place.
  • Kirk Bolt-in Roll-bar
  • VAC Seat mounts
  • Recaro Profi SPG seat (Driver)
  • 6-point Schroth Profi II Flexi-belt Camlock Harness (Driver)
  • Recaro Pole Position seat (Passenger)
  • 6-point G-Force Pro 3” Camlock Harness (Passenger)
  • Alpine CD Stereo w/Bluetooth
  • A/C blows cold/Heat and defrost work
  • Power windows and Power locks work
  • Aluminum Door Panels (front) - **Not installed, but included (with mounting hardware & pulls) with sale
  • Includes OEM Spare wheel/tire.
Known Issues:
  • Front drivers door needs new door brake.
  • Transmission could benefit from detent service.
  • Drivers side skirt clips - some broken.
  • Rear subframe showing minor surface rust.
  • Paint quality: Track Car
*Maintenance records from 2012 thru 2021
Wheel Automotive side marker light Car Tire Vehicle
Wheel Tire Car Vehicle Plant
Car Automotive tail & brake light Automotive parking light Vehicle Vehicle registration plate
Wheel Automotive lighting Car Hood Vehicle
Car Wheel Motor vehicle Vehicle Automotive tire
Car Vehicle Land vehicle Vehicle registration plate Grille
Wheel Tire Land vehicle Car Vehicle
The best is Watkins Glen International, nicknamed "The Glen", is an automobile race track located in the ... This is the first concert that WGI has held since the Summer Jam.
