Picture 1
Picture 2
Picture 3
Picture 4
Picture 5
Picture 6
Picture 7
Picture 8
Picture 9
328i
4-door
5-speed
Color: Carbon Black
Previous owner:
Rebuilt motor at approx. 110k
Conforti Shark Injector
S52 Cams
Euro Clear Tails
M3 Mirrors
M3 Front Bumper
M3 Rear Bumper
M3 Sideskirts
Custom CSL Trunk
Custom Vented Hood
Blacked Out Roundels
Alpine Flip Screen IVA-C801
Boston Acoustics 12" Sub
Infinity Crossovers, Mids, and Tweaters
MA Audio M689i Amp
MTX RT202 Road Thunder Amp
@160k:
Cosmos V2 Cold Air Intake
UUC Twin Silencer Exhaust
PSS Coilover Kit
TMS Front Control Arm Bushings (street)
Meyle Front Control Arms
Expanding Rear Trailing Arm Bushings (forgot who makes these)
Rouge Rear Trailing Arm Bushing Shims
TMS Aluminum Rear Shock Mounts + Reinforcements
Sachs M3 Clutch Kit
Fidanza Lightweight Flywheel
M3 ZF Manual Transmission Swap (98k)
UUC Race Transmission Mounts (red) + Transmission Mount Enforcers
M3 Driveshaft (less than 100k)
3.15 LSD (less than 100k)
M3 Slave Cylinder
Understeer Short Shifter (Mz3)
UUC Stainless Steel Clutch Line
UUC Double Shear Selector Rod + Effort Reducing Kit
UUC Derlin Shift Carrier Bushings
UUC Clutch Arm Bushing
DDM Headlights (55w 5000k HIDs, thinline AEs)
DDM Smoked Corners
M3 LTW Motorsport Moldings
@163k:
UUC Underdrive Pulleys
Fan Delete Mod (80c thermostat, 80/88c fan switch, water pump nut, water wetter)
Bimmerworld all aluminum Radiator
UUC RK6A Shift Knob
DDM Alluminum Pedals
Max Velocity GTR Lip
Wheels
Linea Corse Lemans (18x8.5 all around)
Federal SS 595 (225/40, 75% thread)
Random Maintenance:
Accessory Belts
NGK Spark Plugs
Valve Cover Gasket
Metal Impeller Water Pump
Upper + Lower Radiator Hoses
Aluminum Thermostat Housing
Front Shock Mounts + Reinforcement Plates
Lemforder Tie Rods
Rear Spring Pads
Guibo (Flex Disc)
Driveshaft Center Support Bearing
Differential Output Shaft Seals
Differential Nose Bolt
Selector Rod Pivot Joint
Up for sale is my beloved 328i. All fluids were flushed within the time that i've owned it and changed regularly when appropriate. Odometer is at 174,xxx now. As you can see, all the mods were done within a few thousand miles. Here is an archive of all the old pictures i have.
http://www.mlylaw.com/mlylaw/kyle/e36/e36.htm
The Bad:
There are no windshield washer nozzles. The previous owned made the hood without them.
OBC has some errors due to aftermarket lighting. However, everything is working as it should be. I will try and resolve the issue.
Needs a new air filter
The Good:
It has a clean title with no accidents. I am very meticulous with my work and have done all the mods myself since the purchase. The car is very rev happy and fun to drive. I tried to accomplish this with the rotational weight loss which complement the cams well. Also, i tried to suspension tune for the street. Aggressive where i thought was necessary, but not going urethane on certain components that would make it too harsh on the street. Lots of shift area work as well. Clean crisp shifts make this car such a pleasure to drive. I guess its all personal interpretation, but drive it and make your own assessment. Its an amazing car!
$8000 OBO
Price Drop!
$7500 OBO
