Hi,
read some threads on Foglight problems, mostly saying to clean and waterproof contacts? If that doesn't work .. my left works, right doesn't, plugged right into left connects and light works so assume its the connection or wiring.. worst case does anyone know if its ok to splice into the left and run it over to the right?
Thanks In Advance..
Ich bin der Modifikator
Hi,
Thanks In Advance..
I had the same issue......just cleaned, lubed & crimped connection ends tighter.......check for power & proper ground with a 12 volt test light.
jb :)
