1 - 1 of 1 Posts
Printers are become essential assets for any organization, offices and home as well. But when it comes to printing quality then everyone consider Brother Printer. Brother Printers are famous for their awesome performance, printing quality and so on. But, they also have system failures and Brother Printer is in error state windows 10 is one of them.
Reasons for Brother Printer in Error State
  • There may be something incorrect with the cables attached to your printer
  • It may befall due to BIOS intricacy
  • Poor internet connectivity can also create this issue
  • Corrupted printer driver and Outdated Printer Driver
  • Parallel Port Setting
How to Fix Brother Printer Error State in Windows 10
  • Make Changes in Ports Settings
When it comes to printers, Windows 10 has a few ports issues. By following the measures:
  • Press Windows key + R> type in search bar "devmgmt.msc" then Press Enter>Device Manager
  • View on the top menu > select Show concealed gadgets
  • Right-click Ports (COM and LPT) > Choose Proprieties
  • Tap Port settings tab in the Properties window
  • Select Use any interrupt on assigned to the port
  • Check the container close to Enable legacy Plug and Play detection > Then click OK
  • Reboot your PC and check whether it fixed the issue.
  • Check the Printer Connection:
  • Default Printer selected should be Brother Printer
  • Restart the Printer and Computer
  • Check the ink levels
  • Check Paper jams
To read these above steps briefly and deeply visit this source: Brother Printer in error state windows 10
1 - 1 of 1 Posts
