a 01 330i engine with a manual trany with 20k miles has become available for $2500.00 will this swap directly into my 94 325i with auto trany also is this a good engine or should I wait for a m any one know the specs of this engine
Engine type-- DOHC inline 24-valve 6-cylinder, Double VANOS steplessly variable valve timing
Bore x stroke, mm/in--. 84.0 x 89.6 / 3.31 x 3.53
Displacement, cc/cu in.-- 2979 / 182
Compression ratio-- 10.2.1
Power @ rpm, hp-- 225 @ 5900
Torque @ rpm, lb-ft.-- 214 @ 3500
Engine-management system-- Siemens MS 43 with knock control (2 sensors); variable valve timing, electronic throttle system, dual resonance intake system, engine cooling & other functions included in control strategy
Fuel requirement-- Premium unleaded
Fuel capacity, U.S. gal.-- 16.6
Battery capacity, amp-hr.-- 80
Alternator output rating, amp./W-- 120 / 1680
Thanks for the info can this be swapet into my 94 325i without to many problems
I am not sure, but I am almost positive the engine mounts are different. However, any difference shouldn't be too great.
Depending on what you have/want to spend, anything is do-able.
Sounds like an M54 engine... Does it come with the DME, and other electronics?
I'm pretty sure that you would have to fabricate some mounting brackets for the transmission and engine.
To answer your question:
Can this be swapet into my 94 325i without to many problems
What is your definition of many problems? For one the gauge panel would probably be incompatible with the DME, there are a lot of electronics involved in the e46 along with checks double checks and triple checks. The slightest foul up will cause a check engine light (good luck with getting a smog check). Not to mention you are talking about converting an OBD I to an OBD II car. Like they say with the right amount of money you can do anything (at least that's what I say). You will probably spend 3 times as much money putting an OBD 2 engine and electronics system in there.
To answer your question yes you WILL have problems.... For the price of the electronic systems that you would have to add you might as well buy an E46.
danm thats a really good deal considering the 330i has similar numbers to a 95 m3 which are hard to find for 2500 (engine/tranny)
