I have an e39, 530 – 2002 with 386,000KM.
From time to time, I face difficulty to start the engine & the RPM will drop for few times before it fires & when I shift to D, it will drop again. Any thoughts or ideas?
Depends on your engine (petrol diesel) etc..
You could try taking it to a garage for a proper diagnostic.
Or you could could buy yourself a Haynes manual and try checking the battery power, terminal connections, defective starter solenoid or switch , starter motor, air filter dirty or clogged, ignition components damp, spark plugs, etc, etc, etc...
Hell when was the last time it was serviced?
Good luck!
I have petrol engine
1.The battery is ok.
2.Starter is also ok
3.Air filter dirty is cleaned & ok
4.Spark plugs are new & ok
5.Check engine light is not coming on - ok
6.Gas filter is new – ok
7.O2 sensor – what are the symptoms for faulty O2 sensor?
even if the light is not on the code should be stored and check MAF
