Where is it?
I have been trying to find it in my car and I can't. I think the engine was changed and the ground wire never installed.
Also, could someone provide several pictures of the stock 325 engine bay?
Thanks.
Bimmer engine ground is on the right side motor mount. Chassis-to-engine.
For the upper engine electrics(to run injectors and sensors), there should be a ground wire also in the rear of the cylinder head body(not the cover) to the firewall.
Ground wires in bimmers are color-coded solid brown.
Really, there's no harm in having more than 1 engine ground if only to secure good contact.
