It depends on what type of bulb you use, if you use halogen then it will basicaly be the same just more focused with the ellipsoid, but if you use xenon it will be a bluish look, and if you use hyper white bulbs it will be hyper white.
My Fogs are Philips D2S My Heads are D2R same type of ballasts same color But my Depo projectors cut off line has a very thin blue strip Audi TT projector puts out little more blue strip and my X5 projectors has a huge blue cutoff line I'm going with the X5 set up in spring. Maybe try to retro fit the TT projector in my fogs. :rock :rock :rock
