Hi i bought a retrofit set od hranám kardon And in strugglin with Harman switch button mám WHO sent me this set packed switch with piece od cut connector but in the Harman wiring loom i can't fond any similiar connector to the switch pro another in location nese the rádio connector where IT should be the wiring Is from 2003 And in OEM i can't find number So in bit Lost Now in photos you can sebe what i got with set And that Black connector i ONLY one that coupe be to switch but i can't find aby number oř right switch oř Is IT possible that IT can ve controlled in rádio ?
