1 - 20 of 36 Posts
I don't know what TP stands for but when it is turned on your radio will tune to traffic reports when they are broadcast and tune back to CD or other radio station you where listening to when done.
Hello
I'm new to the bimmerwerkz crew but i'm sure I will be here a bunch. Need some helpon chaging the rear side marker lights on my 94, 540
My cd player was ripped out/stolen so i want install a car computer. i want to use the head unit to play sound via the aux in connection where the cd was . How do i get the radio to know that an audio input is connected via the cd input box in the boot?
Pretty simple mate, once you remove the covers from inside the boot you will see, from memory 3 or 4 screws that you just screw out, the lights will pull out once these are screwed off. Disconnect the cable pin. You might have to pull a bit hard to take it off as it has been there for a while. They tend to stick on a bit, there is no clips or anything you have to worry about, just the cable pin.
Ok now what is the boot is it inside the trunk or behind the rear wheel? Thanks for the rest I can do this.:)
Thanks a lot. I am new to the site.
I have just purchased a 1998 540i with 77000 miles and it came with no books so I don't have a clue as to how the car operates. It is extremely difficult to find an owners maanual.If I find one I will post.
1 - 20 of 36 Posts
