Someone please help me! I have a 1997 BMW 528 that I LOVE and had a very strange issue yesterday. In the morning my car started to overheat so I pulled over checked the upper/lower radiator hose no leaks nor any leak from the radiator. Let the car sit for 10 minutes, then it was fine for the next 5 hours. Later in the day same problem. I let the car sit and this time I could only drive for about 1/4 mile before I had to kill the engine. I did this for a couple miles then called a tow truck. When the tow truck dropped my car the behicle wouldnt start at all. The accesory lights came on but nothing from the started. A jump wouldnt work either. I thought my thermostate or water pump was the issue but now I am worried its something much greater like a head gasket? Could I have seized the car? I killed the engine every time it reached a certain point. Also the belt is in tact. Anyone have any thoughts I would greatly appreciate it....
Steve
You will have to remove the spark plugs, then get a socket on the bottom crankshaft wheel nut and see if the engine turns, make sure its in 'N'
When you overheated, you reloaded coolant... BUT you did not bleed the cooling system and purge it of air bubbles/pockets trapped inside the engine. The bleeding process is a must for every bimmer, and air in the cooling system generates steam which the car reads as "overheat".
Confirm also that your engine did not blow a head gasket. check ur oil level... if it is abnormally high or "coffee n cream' in consistency and color... then that means that oil and water are mixing in ur system.
