Hi all, how r u?!
i have a strange problem with my E39 :conf
this is the case exactly:
sometimes when i switch the car on, the headlights work automaticaly (without switching them on) and due to that, the signal lights stop working as well as the back lights!
and the lights Switch do not response at all
i went to an electrician and he reset the computer by unplugging the battery cable! after that it went away!
then again after like 10 minutes it happened again... but this time in a different theme :help
the second time, when i switch the lights on the right signal works by it self!!!
i thought it may be the computer board of the lights and checked it and it was OK!
so now i ended up resetting the car everytime this happens!!!!
any idea's!?!? did this happen to anyone of you?!?!
Thanks All!
Thanks All!
