1 - 10 of 10 Posts
its a common mod.
and you need to change those rims STAT!
http://hidforum.com/diy/e36bixenon.php
that link explains how e39 projecotrs can be fit.
the ellipsoid headlights for the e36 already have many angel eye kits in them.
combine the two and you have an e39 HID light with angel eyes in a e36 housing.
I don't konw about E39 projectors cause I only got one but I do have a set of X5 projectors they're huge gonna put then in this weekend will post some pix. Far as angel eyes I don't like the rings came with my lights they are too cheap gonna change them also gonna get this set power it with real D2S HID so they are white not LED white but HID white. :rock
Discussion Starter #6
no nuthin like that i want to put the whole light assembly in 1 piece so it will have 540 i lights with hella angel eyes i just like the look of the 5 series front lights.Thats why i have never seen a e36 with those lights.I already have cut my lenses off and installed angel eyes
cut the lense off?
and why is only one side lit?
As for the 5 series assembly, it could be done, but it would require a new nose panel, fenders, and probably hood, all custom.
I once saw one on a cheap bmw mag some where the whole front was M5, also got some diablo doors look real good but if you look little closer none of the panels actually lined up the whole front end of the car was off. Looks good from far thou.
Discussion Starter #9
i have the oem headlights that are plastic so with a dremwl i cut the glue off from the inside.The reason only one side is i did one at a time that night i finished 1 and my friend took the pick
Well if it was the other light, you could have said that you took that light out and made a new intake for yourself....I think I actually saw that somwhere, they took out the drivers side light and made a ram air intake sorta deal...
1 - 10 of 10 Posts
