im not sure about 328i, but i know a 328is owner, he does lots of bmw research and says a 328is has the same gearbox as an e36 m3!!!! do some more research, and ulll find o ut
It'll fit fine....
why would you want to though?
the tranny can handle the same amount of power as a 328 and has the same number of gears. Seems like a waste of money unless your original is blown and you found a cheap m3 to replace it.
yes I do have an automatic my old transmision needs to be replaced and all I can find are trannys for m3s anyway do any of you guys know about the output flange , and also can i use the one from my old tranny ? thanks
