Hi, i have a problem with my 318is coupe which was running fine up until a few days ago. The fuse for the instrument cluster and rear driver side tailight and reg light blew. SO i changed the 10amp fuse and all was fine for an hour or so, then it happened again, so i changed the fuse again.
Then when i got home i removed the key from the ignition and the car was still running!! I had to stall it to stop the engine and then the ll the lighst and the fans were still working! I opened the bonnet and checked the fusebox to find the fuse that ihad replaced had melted! once i removed they melted fuse the electrics stopped and the car would start and stop as normal...now the weird bit... with that fuse removed the instrument cluster is constantly on even when the lights arent on, and the central locking and electric windows have stopped working even though the fuse for these has not blown.
Dont want to spend money on an expensive auto electric ian, can anyone help?? Its a nightmare with no windows in the summer!!!
