1 - 20 of 26 Posts
Retired administrator
Based off the E34 535i, the Alpina B10 adds a couple of Garrett T25 turbos to boost power BIGTIME...
I'm looking into getting an E34 540i 6-speed and I really love the B10 look. Anyone have any idea if I could find an Alpina lookalike kit?
Engine
3430cc, Inline 6 cylinder, twin turbo
Bore / Stroke
92mm / 86mm, Mahle Pistons
Compression Ratio
7.2:1
Block / Head
Aluminium Alloy / Cast Iron
Valve Gear
SOHC, 2Valves per cylinder
Ignition
Bosch Motronic M1.2 fuel injection
Max Power
360 Bhp (PS-DIN), 268Kw (ISO) @ 6000rpm
Max Torque
384 lb/ft, 521nm @ 4000rpm
Turbochargers
2 x Water-Cooled, matched Garrett T-25
Transmission
5 Speed Manual, Getrag 290
Differential
25% Limited Slip with Alpina cooling fins
Suspension front
Independant McPherson Struts
Suspension rear
Semi-Trailing arms, Fitchel/Sachs Self-levelling
Steering
Recirculating, Power Assisted, 3.2 turns lock-to-lock
Brakes Front
Lucas/Girling 13.0" (330mm) vented, 4 pot caliper
Brakes Rear
11.8" (300mm) disc, 2 pot caliper
Wheels
Alpina 20 spoke, aluminium
Tyres
Front 8.5J 235/45/ZR17, Rear 9.5J 265/45/ZR17
0-60mph
5.2 seconds
0-100mph
12.1 seconds
Quarter Mile
13.2 seconds
Top Speed
179.2mph
Standing Km
L/100km
[email protected]/h, [email protected]/h, 17.4 City
I think I just soiled myself ....
so you are looking for a way to turn a regular 535i in to this monster?
Ah jeesus, I soiled myself again ...
you are nuts trigg
:bow :bow , thats one car i would love to own! :bow
Discussion Starter #13
Originally posted by lwebb12@Oct 7 2003, 06:19 PM
you are nuts trigg
:D :D :D :D :D :D :D :cheers :screwy :lmao2 :lmao2
Discussion Starter #14
The project will probably happen quite a bit down the road, but I'm looking at getting a pair of small turbos ball bearing Garrett T25s would work fine, and boosting about 12.5 to 13PSI max. That would be equivalent (but infinitely more efficient) to the Dinan stage 3 supercharger which produces about 426hp and 398lbs/ft of torque. I plan on running each turbo through it's own individual intercooler (probably going to try to Ebay ICs from a 300zxTT, it uses individual ICs) and back into a main intake manifold, most likely a modified version of the stock one. I'm also going to see if I can possibly find a performance engine rebuild kit so I can have a fully balanced motor. I'm also planning on Dinan exhaust and Dinan hot cams (unless anybody else makes good quality E34 540i parts) I'm still trying to figure out how to rig up Air Mass Meters to run in parallel. Anybody who knows about this, I would appreciate it.
I mostly just want the Alpina body for it's beauty. I can promise that the car will go much harder than any B10.
check on the Nikasil in the E34 M60/2 engine before tossing high power mods.
an updated engine with Alusil should be installed
are you ditching the miata project trigg, or is this an idea for a post miata project? alpina also has a E39 D10 bi-turbo, but i think i'd rather the looks of an alpina e34 :wub:
Discussion Starter #18
not ditching the miata project, but rather looking for a good daily driver replacement for the mule, who has become ill lately. Leaky seals and such arent worth fixing.
I'm sure that Alpina stuff is available in Europe but it's probably impossible to find in the US. I bet Fatty knows where to hook up with that stuff since he has an Aplina replica.
1 - 20 of 26 Posts
