1 - 1 of 1 Posts
Im new on this forum and wondered if anyone could help me with this problem,when i change gear on my 535i sport i get a clunking noise from the rear drivers side wheel and also if im driving in a straight line and i lift off the throttle the car rear-wheel steers at the same time as the clunking noise. Also if i park the car with the handbrake on,select first gear and bring the clutch up enough to just start biting you can actually see the wheel moving backwards into the wheel arch!!!!! Ive been told its probably a worn suspension bush but which one could be causing this problem and where can i get the new bush from ?
1 - 1 of 1 Posts
