Hi i have a (1995) 525 m51 td, when cold starts and runs, however when hot will stall and fail to run, I have changed the heater plugs, lift pump and even tried a running it on a full tank incase it was a lack of fuel pressure
When it is hot, it turns over and runs lumpy for a few seconds and a doesnt have any accelrator control then stops, once cooled down it will start and run lumpy with still no accelrator control then will drop revese below 500rpm and start to tick over normally ?
can anyone help. I have ordered the carsoft diagnostic tool to hopefully check and identify the fault, however nothin is comming up on the dash to identify a fault ?
thanks in advance
J:conf
thanks in advance
J:conf
