hey guys, how goes it.
Ive recently taken on a project of turbo charging a friends 1986 E30 325e.
Everything was going well, until i was asked what i was going to be doing about the MAF and if i was going to be changing to a HFM?
Can you guys potentially help me out and tell me what a HFM is? Im a domestic guy that has a love for european cars, but i dont know about some of the products, like in this case, nor do i want to ruin the car due to my lack of knowledge.
The run down on the 325e:
Jim C chipped ECU(will need reprograming once the turbo goes in)
modified 524TD manifold
Garret T3 Super 60 turbo
Turbonetics Deltagate Mark 3
Vortech 12:1 FMU
MSD #2225 booster pump
DSM 410cc injectors
2.5" charge pipes
Autometer gauges(EGT, OPG, AF)
custom dual gauge pod
2.5" downpipe exhaust
removed cat/res
Spearco FMIC
blitz turbo timer/boost gauge
IS front bumper
Reigar(?sp) style side skirts
IS rear lip trunk spoiler(not installed/painted)
eibach pro kits
Sparco Front/rear Strut bars
17" Mille Miglia spydar wheels
there is prolly more that i cant remember, but if you guys can help me out i would greatly appreciate it.
ill post pics once im done. :)
Jas
well... from the sound of it your friend is malfunction.
e30s come with AFM, or Air Flow Meter, which is a big trap door which by the amount it opens calculates the fuel used. MAF is different.
By HFM the most i can get out of that is High Flow Meter which maybe is some term he made up for a bigger AFM.
Thats all i can offer. Good luck with your project
Welcome to the forums fuzion!! B) :wave
HFM stands for "Hot Film Meter." An HFM is the same as a MAF (Mass Air Flow) sensor.
Installing a HFM on an E30 is not a plug and play setup. You will need a calibrator such as a Split Second module. There are lots of setups you could run actually, it depends on what exactly you want and how much you want to spend.
no no, you loose power unless you chip the engine first. BMW chips arnt adaptive.
