My specific use is to diagnose codes on my E46 M3 2004, and I can confirm that it works fully with this car (Note: I cannot guarantee that this is absolutely perfect as described, hopefully it’ll get you up and running too).
1. Get a cable
I bought a BMW INPA USB interface from Careucar. This cable I purchased is a USB to OBD2 connector that plugs into BMW to the right hand side of the steering wheel, in the foot-well area.
2. Setup/Configure OBD2 USB cable
1). Put the DVD that arrived with the cable into the DVD drive on your PC.
2). Plug in the cable into a USB port on your computer; you must ONLY use this USB port from here-on for this cable. If your computer is connected to the internet it should automatically search and install in the USB cable drivers. If your computer does NOT automatically detect the cable, you may need to use ‘Device Manager’ to manually update/select the driver.
3).Once installed, go to Control Panel -> System -> Then click on the Hardware tab, then click on Device Manager.
4). Locate the entry ‘USB Serial Port’ in the ‘Ports’ section of Device Manager. It should read ‘USB Serial Port (COMX)’.
5). Right-click on the above and select ‘Properties’, then click on the ‘Port Settings’ Tab and then click on ‘Advanced’.
6). Change the ‘Com Port Number’ entry to ‘COM1′.
7). Change the ‘Latency Timer (msec)’ to ’1′.
8). Click on ‘OK’ and close all the windows, restart your PC to confirm all the changes.
3. Install INPA/EDIABAS 6.4.3 and 4.4.7
1).Extract the contents of the downloaded file ‘INPA-6.4.3-full.rar’ and you’ll find a NRG file. This is a CD image that you’ll need to either burn to a CD or extract to a folder using a tool such as ISOBuster.
2).Once extracted, go into the following folder ‘/REFERENZ/INSTALL/’, right-click on ‘INSTPROG.exe’ and select ‘Properties’, click on the Compatibility tab and change the dropdown to Windows XP SP3 as the Compatibility Mode, also tick ‘Run As Administrator’, then click ‘Ok’, then double-click the file to run the installation.
3).Select ‘English’ as the language and click ‘Next’.
4).Select ‘Next’ until asked for ‘Configuration’, scroll to ‘BMW Group Rectification Programs UK’, click ‘Next’.
5).Tick the option ‘Complete’ for all of the options shown.
6).Select ‘Next’ and allow the installation to start.
7).After a minute or so, installation will complete, close the Window.
4. Verify environment variables
Go into Control Panel -> System -> Advanced System Settings.
Select ‘Environment Variables’ and then verify that the System Variables ‘TMP’ and ‘TEMP’ both contain the path ‘C:\EDIABAS\Bin’ within the ‘Value’ string – for instance “C:\Windows\Temp;C:\EDIABAS\Bin”.
5. Prepare Installation Files
Extract the contents of the downloaded file ‘INPA_502_Updated.rar’.
You’ll use the contents of this archive during the next three steps.
6. Install BMW Tools
1). From the above extracted file set, find the file ‘Step 1_ Install BMW Tools.exe’, right-click on it and select ‘Properties’.
2). Click on the Compatibility tab and change the dropdown to Windows XP SP3 as the Compatibility Mode, also tick ‘Run As Administrator’, then click ‘Ok’
3). Double-click on the above file to start the installation.
4). Set the Destination Path C:\BMW Tools (Don’t change this path) -> ‘Install’ -> ‘OK’.
5). Select ‘English’ -> ‘Continue’ -> ‘Continue’.
6). Select ‘C:’ -> ‘Continue’.
7). Select ‘Skip’ -> ‘Next’.
8).Accept the defaults for programs to update, then click ‘Next’.
9).Select ‘Com1′, ‘OBD’ and ‘USB to Serial Adapter’ -> ‘Continue’ -> ‘Continue’.
10). The installation will begin and complete.
7. Install INPA/EDIABAS 6.4.7 and 5.0.2
From the above extracted file set, double-click the file ‘Step 2_ Install INPA.exe’.
The Destination Path should be ‘C:\temp’, leave as it is and click ‘Next’.
Choose ‘English’ and select ‘Continue’ and ‘Continue’.
Select ‘C:\’ and then ‘Continue’.
Select ‘BMW Group Rectification Programs UK’ and click ‘Continue’.
Tick ‘Update’ for all options were not grayed out, then ‘Continue’.
Select ‘OBD’, then ‘Continue’ and ‘Continue’.
8. Install OBD Setup
From the above extracted file set, double-click the file ‘Step 3_Final Update.exe’.
The Destination Path should be left as it is, then select ‘Install’.
Select ‘Yes to all’.
Once completed, the window will close itself.
9. Complete Installation
From the above extracted file set, double-click the file ‘serial port.reg’.
When prompted, select ‘Yes’ and ‘Yes’. You will receive confirmation that your registry has been updated.
Locate the file ‘C:\EDIABAS\Bin\obd.ini’ and copy this file into your Windows folder.
Edit the file ‘C:\EC-APPS\INPA\CFGDAT\INPA.INI’ in Notepad, locate the section that starts with ‘//F3′, remove the slashes at the beginning of the three lines of text, and amend any instance of ‘F10′ to ‘E46′.
So far, all above is the whole process.
Hope it is useful to you!:smile:
Nice write-up. Is this EDIABAS cable possible to find some functions that hidden from the iDrive unlock/lock door alarm, like enable the full bluetooth option in the car so i can play music from the iphone to car via bluetooth?
