1 - 9 of 9 Posts
Got a question, i know what coilover suspension is... the shock inside the coil... but what is the advantage of it?
biggest one usually is that you are able to adjust height of the coilovers to accomodate your driving habbits. that is if you have adjustable coilovers.
so you can drop your car easily with coilovers?
Nice i need to get me a set of coilovers i was going to buy 250$ springs off of bavarian tha drop it like 1 3/4 but maybeill go with coilovers how do coilovers instal? how can you change the heights? and how much do they cost compared to those springs?
David
coilovers are adjusted usually by turning an adjustment knob that will raise or lower the car. Coilovers cost substainally more than springs alone, so be prepared to shell out some extra cash. Coilovers install just like regular springs.
depends on if you install or a shop, but a minimum investment of 1100 is needed, and more if you want bilsteins.
1 - 9 of 9 Posts
