Hey another problem is have is when i put my alarm on it does not lock the drivers door but locks every other...... Its the same thing as when i unlock it via my alarm remote key fob....
I have a sigma T2 bmw alarm if it helps.. I just find it annoying that it locks/unlocks every door apart from the drivers side.
Is this normal or is something wrong?
Cheers.
Ich bin der Modifikator
OK cheers... i need another door anyway.. Just out on intrest will i have to keep my key barrel from my original door? reason i am asking is i might not beable to get the keys from this door i am buying.
Yes you will need to keep your barrel, the actuator is not a bad job to do just a bit fiddly, I had to do one on my rear door, I took the actuator apart re greased it with silicone grease, no trouble since....
