BRAND NEW set of
BBS CH silver Rims 5X120 bolt pattern
Plus a BRAND NEW set of
TOYO PROXES FZ4 Tires
What you get:
4 Brand New BBS CH silver rims
20 Brand New BBS lugs with specific key for anti-theft
4 Brand New BBS valve covers
4 Brand New Toyo Proxes FZ4 performance tires
Wheels are Mounted and Balanced Ready to Put on Your Vehicle
BBS CH SPECS:
Size: 18 x 8.5 ET: 35 Weight: 23.9 lbs
Wheel Technology: CH - One Piece Counter Pressure Cast Wheel - Spun inner rim using BBS Flow Forming Process - Weight optimized by FEM analysis
TOYO TIRES SPECS:
Steering Response Refined casing profile
Jointless cap and edge ply (construction may vary by size)
Two full-width steel belts
High-hardness bead filler stabilizes lower sidewall
High-grip tread compound
Style High-image sidewall styling
Aggressive unidirectional tread design
Large shoulder blocks
All-Season Traction Unidirectional tread design with double “V-shaped” lateral grooves
Special tread compound optimizes all-season traction
M&S rated
Comfortable, Quiet Ride Refined casing profile
Jointless bead wire
Polyester casing for a smooth
Jointless edge and cap ply construction (construction may vary by size)
Tread designed for minimum noise
Tire Size: 225/40ZR18 92W RD Product Code: 189880 Tire Weight: 21 Tread: 10 Diameter: 25.1 Width: 9.1 Static Loaded Radius: 11.8 Max Load: 1388 Max Pressure: 50 Revs Per Mile: 831
SAVE A LOT OF MONEY FOR A VERY EXPENSIVE SET OF WHEELS WITH THIS BEST DEAL YOU WILL NOT FIND ANYWHERE ELSE.
FOR PAYPAL PAYMENTS ONLY, PAYPAL CHARGES WILL BE PAYED BY BUYER.
I am an honest seller and you cannot find such a low price on a brand new set like this anywhere!
What you get:
BBS CH SPECS:
TOYO TIRES SPECS:
M&S rated
Jointless bead wire
