Greetings
1995 e36 325i
Brake lights don't work and OBC reports brake light circuit error.
Checked fuses and bulbs.
Suspect brake swith on the pedal though its active since I can shift transmission out of park.
checked wires near trunklid with nothing frayed or broken
would switch still be suspect though there is some symptoms of a closed circuit?
any thoughts would be considered..
thanks
eddie:help
Ich bin der Modifikator
Greetings
1995 e36 325i
thanks
eddie:help
Yes.......the switch is commonly known to be the culprit! What happens is, just the slightest break in continuity will trip OBC.
I had to replace the brake switch, after a couple of months of owning my E36.....
Pelican Technical Article: BMW Brake Switch Replacement
jb :)
As I suspected
I replaced a couple of these switches on my land rover though it would fail completely. (couldn't shift out of park).
thanks for the attachment. I suspected I would break it to remove it, though I will wait till I have the replacement in hand...
again.. thanks for the reply
eddie
