Unblock the drainage channels.....grass strimmer cable works great.
42, The meaning of life
Welcome to the Werkz. Just in case your unsure about what Marti is referring to, there are drainage lines around your sunroof.
Thank you Brett, I was in a hurry this morning!....so open the sunroof, you should see holes at the two front corners, some models have the at all 4 corners,gently feed the cable/twine down the holes to clear the blockage and pour some hot water down them while pulling and pushing the cable/twine, you should see water coming out from under the car.I do mine once a year normally october/november just before winter hits here in the UK.
