So I just got a great condition 1986 325es with the intention of just putting a little bit of work into it and then using it as a daily driver. After more and more research though I am starting to itch at the possibility of doing an engine swap and turning it into a little sleeper road rocket.
From the research I've done it looks like the most common swap is to an M50/M52 or S50/S52
I have never swapped an engine before although I am very mechanically inclined and decent at fabricating, I have also never had an e30 before, or any old BMW at that.
I have also heard of doing just the head swap of a 325i but have seen a lot of people down talking that as well.
I want a good amount of power for cheap and hopefully not be too difficult.
The car currently has the 5 speed tranny that came with it and because I've never done an engine swap I'm wondering what else will I need to get to make things work? New diff? full new tranny? engine mounts? harness adapters?
What would you suggest I do and can you point me in the direction of some good info?
Lastly can you give me a ballpark price range for a job like this? I would try to do everything myself as I have access to all the necessary equipment but you have to remember I have never swapped an engine before and might need to call in some paid experts. I don't really want to spend more than 5k and that includes new suspension and wheels and tires.....
Thanks for all the help and the patience you have with a newb like me.
Cheers,
Tyler
Cheers,
Tyler
