1 - 15 of 15 Posts
I tried pairing my iphone to my 06 750 Li and it requested a Pin to pair. I bought the car used so it must have an original pin established. Usually when you pair most bluetooth devices, when you discover the device, any code will work. Does anyone know of how maybe I can reset it, or know if there is a master pin? I'd hate to take it to the dealer and leave it all day for something I could do on my own.
Inside the boot/trunk, on the left side behind the DVD player, there is a box that sits at a 45 degree angle. Right above that box, there is a box that is shaped like a VHS tape. Unscrew that box and on the other side you will see bluetooth PK: and your four digit number.
Thank you so much! I will try that tomorrow morning! Merry Xmas!
Merry Christmas to you too.
42, The meaning of life
Marti, how do you know all this stuff?? You are a fair dinkum legend!
Most of my knowledge comes from answering questions with possible solutions and as we work through the problem bit by bit and come to the solution I learn the cure and all the possible cures along the way,then just store it in my head, also I read nearly every topic posted and gain knowledge from them for future reference.
Have a good Christmas brettski.
Cheers Marti, I hope that you aren't suffering too much with the cold weather you are having. Have a great Christmas and New Year. Speak with you soon.
Discussion Starter · #8 ·
Do I need to remove the DVD Changer? to get to where you are talking about... attached is a pic of what my car looks like.. please advise.. thanks.
Discussion Starter · #10 ·
I thought it would be as easy as you say... unfortunately Im not so lucky...
I had the same problem with my 2006 750Li and the Dealer was able to pull the code with no problem. No charge. Mine was a Nokia 6085 phone and was not on the approved list of BMW phones but it worked just fine.
Yes, I did say behind the DVD player
Just thought I would say a big thank you for this thread. I have just brought a 2007 (56) 730d without the Bluetooth code. The box wasn't quite in the same place as mentioned above, it’s to the right and above the Sat Nav DVD player. No need to remove the DVD player, there is one of those press-stud type fasteners holding the boot lining panel in place about the same level as the DVD player but further into the boot. Take that out, release the liner from the boot seal, pull the liner forward slightly and the VHS size box is there in plain sight. Simple!! ;)
Depends on you model sir....
Discussion Starter · #15 ·
yeauoooo... Thank you Yoda!:eek:hnoes
1 - 15 of 15 Posts
