Hello Friends, this is regarding 2005 745LI, I have recently changed coolant Thermostat, Upper and Lower Coolant sensor and Radiator fan. I keep on getting Engine overheated at 107C. The Water pump is working fine as I can c a steady stream of coolant in coolant reservoir. The coolant is between Min and Max range (no coolant leak).
Upper radiator hose is HOT and lower radiator hose is warm to touch.
I am able to drive for 30 mins continuously and the message keeps on popping and disappears and this cycle continues.
Any help is demystifying this issue is much appreciated.
Thank you.
Thank you.
