Ich bin der Modifikator
The charge light does not come on when key is in position 1.
NOTE-
If the warning light does not come on, repair any wiring or bulb faults before continuing to check the charging system!
Maybe the bulb is out which completes the circuit to D+........if not, recheck your wiring......
Discussion Starter · #5 ·
I had to disconnect the negative cable for the alarm to reset.The alarm seems to be working.When I turn my key to position 1,the charge light does not come on.It says to check for bad wiring or a bulb.Is there a starter relay somewhere?
I think you have start looking in that area, meaning the bulb & the wiring.......there is nothing wrong related with the starter........because, when you jump start your car, it starts.......that is telling me that when you jump start it @ the engine compartment position, you are bypassing the issue, with either the charge warning light bulb that supplies 12 volts to D+ on the alternator or the wiring issue is being bypassed.....
Listen, you had the a the alternator out, there are 3 wires in the back, are you sure they are on the correct terminals.......I would double check that 1st, if that checks out Ok.......then I would remove the gauge cluster & check the bulb......
link on removing gauge cluster:
DIY: Installing Silver Gauge Cluster Rings on E36 - United Bimmer Community - BMW Forum
jb :)
