I have this leak when it rains that is over my battery which caused my BST harness to short, thus causing my airbag light to go on. Has anyone experience this problem? Would this be covered under the warranty?
Has anything been "touched" before in the area (ie. any previous work or aftermarket installs)? I would look at the tail light assembly. Check to see if it has water in it as well as check the seal to the body. I have seen where a leak from the tail light assembly would cause the problem you are describing. However there are multiple possibilities.
do you know where the leak is coming from? as stated before, check your tail lights and the seals. you may have a broken seal somewhere. this should be covered under warranty.
A forum community dedicated to all BMW owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more for your favorite models!
