Hi guys
I had a prob a little while back with the ABS light commin on. I took it in to BMW and they replaced the 2 relays and ran a diag on the rest of the system and there was a small fault on one of the speed sensors on one of the front wheels. they cleared the fault codes and let me run with it to test. I then noticed that if I reach about 160 km/h and the ABS light comes on again. Any one got any suggestions as to what could be causing it?
thanx in advance
laters
they cleared the codes, but didn't replace the faulty sensor? maybe that's the problem.
also, did you radically change wheel size?
well they did change the relays because i can see they are new.
the wheel size is the std size, havnt changed yet.
its back in the shop today so we'll see what they say
