Hello everyone, I just found this great forum and it has been a fountain of information. The only problem is that I'm not sure my question has been covered before since the search button doesn't seem to work for me. Anyway, here goes. A little while ago I was replacing my rear-wheel bearings and for some reason I had to take out the ABS sensor. After the job was completed, I put everything back in place and from that point on my ABS light has been on. I tried taking out the sensor cleaning it and then putting it back in... no luck... Then I tried the oposite putting some grease on the sensor (since it had some to begin with, and again, no luck. What can I do now? It's obvious that I did something to it when I pulled it out, but will replacing it solve the problem? Why would this happen?
Javiwwweb :banghead
My guess is that pulling the sensor flipped a bit in the On Board Computer. Translation - you probably need to take it a dealer and have them reset the light for ya, or get a tool that does the resetting.
Good luck, cheers, welcome to the forum, and next time wipe you feet huh. You tracked mud all up in this bizznotch and I gotta bust out the mop now ... *grumble grumble*
Hey welcome javiwwweb!! B)
Like GD stated you'll prolly going to have to have your OBC reset because the ABS sensor set off a fault code in there when you took it off..there is a way to do it yourself but I recommend you take it to the dealer on this one!! ;)
try getting the fault cleared , mechanics will use the modec tool. anyways , if that fails at least youll know whats wrong , with ABS it could be a few different things, left or right, speed sensor, brake sensor, etc etc
