ABS problem that has been diagnosed as the ABS Control Module. Where is the ABS Control Module? Is it a separate part from the ECM?
It is mounted directly under the Brake Master Cylinder:ABS problem that has been diagnosed as the ABS Control Module. Where is the ABS Control Module? Is it a separate part from the ECM?
