Hi Gentelmen
I have noticed that ABS and ASC signs were beaming together at the same time.
This happened for me 4 to 5 times. Some times happen to me while
my driving
Is this a common thing and it will go later or there is a really problem in
the car.
what shall i do.
Hello,
I have the same problem now !!!
Have you got some info ?
BMW changed the sensor but the problem is still here..
On the road (clean). It seems that if I drive under 60 km/h I will have the problem, If I drive over I will not have the problem ....
Strange ...
Really, the only thing to do is have the fault memory checked. You may have a control unit taking a dump (it happens alot). If you have any warranty, definitely take it in.
Dwarf, I would take it back and have the dealer check the faults and perform a test plan on the system. They shouldn't charge you since they misdiagnosed it. I am curious how many miles you guys have on your cars???
