HELP,
I have a 95 525i that will not start, but will start and run (briefly of course) with a little shot of starting fluid.
I have:
changed fuel pump
jumped main fuel pump relay
bridged DME relay
changed crank sensor
added more fuel(plenty of fuel when swapped pump)
checked the fuses
check the plugs(dry)
checked compression(good)
swapped battery
I "DID" find a vacum hose to a diaphram(regulator?) split at the rear end of the fuel rail, but I cut the bad part off and reconnected, still nothing
I cannot believe it is the fuel filter, but I haven't changed that(yet)
Do not know where regulator is but heard there are problems with the plugs under manifold. I do not know "how" to check the regulator on this car...I do not see where to check the fuel rails for pressure without taking a rubber hose-clamped line off...
It will start and run briefly(seconds) and die if I let it sit a couple days and the battery is reconnected after days
It acts like it wants to start, but....
I REALLY WANT TO DRIVE MY CAR, PLEASE HELP!
I have:
changed fuel pump
bridged DME relay
checked the fuses
swapped battery
