1 - 9 of 9 Posts
hey everone, I left my keys in my car ( I locked it by presing down the lock) and my remote won't work ( replaced the battery, thinking that was the problem, no go). :( PLEASE HELP! any ideas (besides break the widow)?
yes the remote has worked before, got mad I while back and threw it, so not sure now :) and I have replaced the battery with a new one....my car battery DID die a while ago (would I have to re-sync it?)
· Premium Member
Have you tried the emergency unlock procedure?
Go to the passenger side and turn the key while lifting the door handle. It should unlock. If not ... I guess you're either gonna have to break something or pay someone to break into your car (which is easier said than done on a BMW). If you double locked the car, breaking in is not an option, and you will have to break glass somewhere.
Discussion Starter · #7 ·
I would have tried the emergency unlock but the keys are locked in the car ( the spare or 'vallet' is in the car, I lost the master) when I get into my car....is it possible for me to have a new master key made? I live in Charleston, SC
Discussion Starter · #8 ·
which would be cheaper, paying someone to break in or breaking the window ( the rear driver-side window comes off the track when you try to put it down and the weather strip stuff is messed up anyway or should I break the qaurter panel [thinking that might be the cheapest option (might not be able to reach the lock if I did though)]
1 - 9 of 9 Posts
