check your compression on all cylinders... take compression readings for both "wet" and "dry"... and that will tell you where the prob lies.
gas in oil =
stuck or leaking intake valves, (maybe adjusted just a little to tight on the intake valve clearance)
worn rings
Discussion Starter · #5 ·
hey darkhorse, i know its been awhile but i found this old post of mine and im still having trouble with the injector, #3 to be exact, i took the valve cover off and i cannot see any way to adjust the valves, been a mech. for years. are the hyd. ? by chance? its an 85 318i
