ok guys need help really bad only car i got to drive right now ok i was driving one day down the road and my lights went dim and my transmission stoped shifting it would stay in overdrive ok then the dash say check control then the car just dies so i charge the batery same thing happens again so i get anew batery and alternator and does it again i put a meter on back ofthe alternator jacks and it read 0 with it running so i need hep any sugestions
Im Bluffin With My Muffin
could be the voltage regulator? was it a new alternator of rebuilt or used?
Checks
its a 92 in any ideals ive bought new batery and alternato stil want charge
G'Day,
Got a Volt /Multi Meter?
What Voltage do you have on the Battery when the car is running?
You should have 13.8V to 14.2V or so.
When doing this also check the voltage at the Alternator.........Oh! You might consider to Charge the battery before you start.
Then, Disconnect the Battery Charger:eek:
If the Battery Voltage does NOT increase to the 13.8V to 14.2V then the Alternator is perhaps cactus.
If you have the 13.8V to 14.2V at the Alternaton;
Then you have an Open circuit between the Alternator and Battery .........BIG Fuse or a VERY BAD Connection.
My Money is on the Alternator.:(
