1 - 13 of 13 Posts
Im Bluffin With My Muffin
Discussion Starter #1 (Edited by Moderator)
when I put the car in gear (not sure on forward but happens every time in reverse) and release the clutch when a certain amount of pressure is applied the is a thump/clunk in the rear end is seems like something is popping out of place..... also notice the rear sway bar on the driver side it almost disconnected from the little arm attaching it to the a-arm.... going to jack up the car tommorrow and take the rear wheels off and check every thing... what should i check.... bushings, mounts, common broken parts? .... thx a million...
~Love and Duckies Nick ;)
Discussion Starter #2
walsru?......any ideas? also i didn't know these came with coil overs stock.... the differential seem to be fine mount seem ok...... and not to much movement in th cv's...
Differential mount could be it.
thanks I'm going to work on the car in a little bit. I'll take a couple photos of the mounts.
Going to replace the Diff. mount, fix the seats and, sand/ paint the car. I got promoted at work so I cant go on there (to the happiness of some of you.. :( ) anymore so I'm out for a couple day and maybe longer(might check back from time to time to check your progress on your turbo install Walsru :) ).. so peace for now
~Nick
Peace ez, we know you'll still be around
(turbo came, going to unpack some of it tonight)
Well two almost 5' tall 70 pound boxes at the house don't do me much good all spread around, I have to get out to the shop to make a mess.
Don't worry, I shoved my arm into the newspaper and felt around until I found the turbo. Pulled it out, checked the rotation and play. IT'S PERFECT!
Discussion Starter #11
just checking in between work and shopping yeah i looked at it... it seem different on the e24.... but seems fine... Pictures of the turbo cleaned and purdy is a must! will check back in a couple days unless I cant figure out the clunk, brakes, rear air blower and pass. seat.
P.S. danny I'll still be the whore for you ;) just have some stuff to deal with here first...
Discussion Starter #13
subframe bushings? Im not sure what they are like on e24's though.
..... lol that was fixed Months ago;)... it was the Diff mount:rolleyes:.... subframe mounts and Diff mount are going to be filled with poly.:rule.. I have a E28 based E24 so it is just like the e28:)..... thanks for the info though;)!
1 - 13 of 13 Posts
